Hi together,
where can i find the XnView MP settings in a Windows 7 * 64 system to transfer the settings from one system to another?
Many thanks
Michael
Copy of XnView MP settings
m.Th.
Re: Copy of XnView MP settings
(Mainly) In the xnview.ini file.
To find the location of this file go to Tools | Settings | Integration | Paths and press the 'Open the Config Files location' button.
From there you can copy
xnview.ini - settings
...and optionally:
autocorrect.txt - (autocorrect entries)
bookmark.ini - (the bookmarks)
..and perhaps the default.bar, default.keys
Attention: you ask about 'settings' and not 'database', right?
...and optionally:
m. Th.
Dinole
Many thanks, it works ! Michaelm.Th. wrote:....From there you can copy......
