It would be nice to be able to put a color label on folders e.g. I'd like to label at the folder level if it is Work or Personal.
Thanks,
Yossi
Color Labels on Folders
orbspider
Re: Color Labels on Folders
+1
and have a color filter at top of folders pane! you display immediately the folders you've color-coded so that you can get to work.
Build Debian http://dquinton.github.io/debian-install/
m.Th.
+1
Standard feature in other DAMs. It helps a lot and it is easy to implement. Just add an integer field to the Folders table and a tab in Tools | Settings to configure the names of the labels.
For example, a screenshot from PhotoSupreme:
m. Th.
See Issue 382 for current status and details.
