Arrow keys non-functional until focus is given to image
VengeArturia
On opening an image, the arrow keys will not perform their defined actions unless the image being viewed is clicked. This behavior was fine in 0.64, but seems to have been changed recently. Is there a fix for this?
m.Th.
Re: Arrow keys non-functional until focus is given to image
VengeArturia wrote:On opening an image, the arrow keys will not perform their defined actions unless the image being viewed is clicked. This behavior was fine in 0.64, but seems to have been changed recently. Is there a fix for this?
Try in Tools | Settings | Interface | Keyboard for the "Left/Right" to put "Automatic" (recommended) or "Previous/next file"
m. Th.
VengeArturia
I've tried both options, neither seems to help. I always seem to have to click the image before I can do anything with the arrow keys, otherwise they simply do nothing.
Someone with the same problem?
nucular
Same problem here. Wasn't like this in the previous version.
Kind of annoying.
Edit:
Tested on Laptop and PC, both Win7 x64.
Problem only happens when the "Fullscreen when starting with a file" option in the settings is deactivated.
The arrow-symbols in the toolbar still work but to make the keyboard keys functional you still have to klick the image.
Kind of annoying.
Edit:
olluz
Same here,
really annoying.
really annoying.
Lebon14
I have registered here to say that I have the same exact issue with v0.68
I might just go back to 0.64 because it's THAT annoying.
nucular
Anyone know where I can download v0.64 to avoid this problem?
Edit:
Found it! - http://download.xnview.com/old_versions ... in-x64.exe
Apparently 0.66 has the Problem as well. 0.64 works though.
Edit:
nucular
For everyone's information. This issue has already been marked as "resolved" in the bugtracker: http://www.xnview.com/mantisbt/view.php?id=361
So it should hopefully be gone in 0.69.
Sablesword
I've started having this problem on going from 0.64 to 0.69.
EDIT Problem only happens when the "Fullscreen when starting with a file" option in the settings is activated - the opposite of what nucular reported for 0.64
This problem is fixed in next release...Sablesword wrote:I've started having this problem on going from 0.64 to 0.69.
