(sorry my English isn't good New COMMAND in Toolbar
moi mon
When I set new COMMAND in toolbar (View Mode), it cannot use
(sorry my English isn't good -
m.Th.
Re: New COMMAND in Toolbar
What command do you want to put there?
m. Th.
moi mon
Example set a command to open 1 exe file.
You can try
You can try
m.Th.
Yes, I can confirm this - I put in c:/windows/notepad.exe and nothing happens. But if you want to open a photo with a certain program you can use Tools | Open with... where you have a more flexible interface.moi mon wrote:Example set a command to open 1 exe file.
You can try
m. Th.
moi mon
I want run a command(s) to edit a batch of images
m.Th.
The Actions from Tools | Batch Convert aren't enough for you?
m. Th.
CreativeWorld
Can be this bug fixed, please? Button with custom command does literally nothing - it should execute some program instead.
yesCreativeWorld wrote:Can be this bug fixed, please? Button with custom command does literally nothing - it should execute some program instead.
