Hi
I just upgraded to 0.68 and in 32 & 64 bits I get this error on first start: "There is a problem to update database (Error 11), please contact developer".
Windows 8.1
Tried also the following, .zip installer, run as admin, deactivate antivirus. Doesn't work.
¿Can i fix this by myself?
¿If i can't where can i get an older version?
Thanks.
0.68 Error 11
m.Th.
Re: 0.68 Error 11
You have some variants:
1. Wait. Pierre will bring soon a new version
2. Hide your databases. See here how: http://newsgroup.xnview.com/viewtopic.p ... 74#p119588
If you think that you "lost" something, then bring (rename) them back.
3. Yes, you can get an older version but it isn't recommended IMHO. In 'General Support' forum there is 0.64 still available.
m. Th.
smartalan
Re: 0.68 Error 11
I had the same issue on my Macbook Pro under osX 10.9.3
I remove the all version XnView MP then reinstall, it is the same issue. Error11.
Re: 0.68 Error 11
Please try this version, and tell me if it's fixed?
Windows ZIP version: http://download.xnview.com/XnViewMP-068-win.zip
Windows SETUP version: http://download.xnview.com/XnViewMP-068-win.exe
Windows x64 ZIP version: http://download.xnview.com/XnViewMP-068-win-x64.zip
Windows x64 SETUP version: http://download.xnview.com/XnViewMP-068-win-x64.exe
Mac x64 TGZ version: http://download.xnview.com/XnViewMP-068-mac.tgz
Mac x64 DMG version: http://download.xnview.com/XnViewMP-068-mac.dmg
If you have always the problem, please send me your xnview.db
ventolinmono
Re: 0.68 Error 11
Yes, it's fixed. Thank you very mucho. That was fast.xnview wrote:Please try this version, and tell me if it's fixed?
smartalan
Re: 0.68 Error 11
Thank you, it is work under osX.
