When I try to use the 'Compare' tool in XnViewMP 0.68 there is an immediate program crash!
I try to use the tool on two selected PNG files from within Browser mode.
I can provide my ini to Pierre for tests
EDIT:- Yes, problem occurs with my ini, I will send my ini to Pierre to test this
0.68 win-x86: Compare tool = CRASH
budz45
Re: 0.68 win-x86: Compare tool = CRASH
when you open it? Do you have the crash dialog?
budz45
Yes, I get this:xnview wrote:when you open it? Do you have the crash dialog?
could you send the report, and write that it's from you
