Option to not show "Up one level" icon as a thumbnail
jorgeo
Post by jorgeo »
If you choose to have fairly big thumbnails, the green "arrow up" icon to go to the parent folder will always show up at the top-left corner of the thumbnail page. It takes the full space of a thumbnail. Since it also shows up in the toolbar, this can be a bit of a waste or real-estate space. There should be an option to not show "parent folder" in the thumbnails.
Thanks!
orbspider
Re: Option to not show "Up one level" icon as a thumbnail
Post by orbspider »
It would be missed by keyboard users with no mouse.
It could be an option though for mouse users.
m.Th.
Post by m.Th. »
jorgeo wrote:If you choose to have fairly big thumbnails, the green "arrow up" icon to go to the parent folder will always show up at the top-left corner of the thumbnail page. It takes the full space of a thumbnail. Since it also shows up in the toolbar, this can be a bit of a waste or real-estate space. There should be an option to not show "parent folder" in the thumbnails.
Thanks!
Go to Tools | Settings | File List | Custom Filter
Uncheck the "Parent Folder"'s "Visible" check box.
m. Th.
jorgeo
Post by jorgeo »
Custom Filter did the Trick, thanks!
