I would appreciate someone's help very much : after a complete new installation of my computer I also installed my old friend XnView again, thinking it would work like always. Then I wanted to open a jpg with the "open with" function and immediately I receive the following information :
Path…./xyz.jpg is not a valid Win 32 application
I updated my old version to 1.80.1/1.50 but it did not help. Strangely after having opened the program I can browse in the tree to folders with pictures and open them. This works but is a bit inconvenient.
Any ideas ? THANKS.
xyz jpg is not a valid Win 32 application
marsh
Re: xyz jpg is not a valid Win 32 application
Open with from windows explorer?Menzi wrote:I would appreciate someone's help very much : after a complete new installation of my computer I also installed my old friend XnView again, thinking it would work like always. Then I wanted to open a jpg with the "open with" function and immediately I receive the following information :
Any ideas ? THANKS.
Hi Pierre,
I just go with the curser on one image (jpeg), push the right mouse button and there it is the "open with" function. Among Photoshop, Imaging, Picture viewer, IE etc. there is also XnView.....
XnView is the only progrm which does not work :
By the way I have and had Windows 2000 SP 4 etc. - had it when XnView worked fine...
Menzi
Menzi
Perhaps a problem in the association...Anonymous wrote:Hi Pierre,
