Database error with 0.68 on Mac and Win7
hago
Post by hago »
Hallo,
I tried to install XnViewMP on Win7 and on Mac 10.8
On both systems I got a message which told me, that there is an error with the database (error 11).
No installation possible.
Is there anything I can do?
Regards, Hago
Re: Database error with 0.68 on Mac and Win7
hago wrote:I tried to install XnViewMP on Win7 and on Mac 10.8 ... On both systems I got a message which told me, that there is an error with the database (error 11)...
Only wait until the issue is finally resolved I'm afraid, hopefully later this week...
If you don't already have XnViewMP 0.64 installed, you could download that version and use it temporarily.
Please try this version, and tell me if it's fixed?
Windows ZIP version: http://download.xnview.com/XnViewMP-068-win.zip
Windows SETUP version: http://download.xnview.com/XnViewMP-068-win.exe
Windows x64 ZIP version: http://download.xnview.com/XnViewMP-068-win-x64.zip
Windows x64 SETUP version: http://download.xnview.com/XnViewMP-068-win-x64.exe
Mac x64 TGZ version: http://download.xnview.com/XnViewMP-068-mac.tgz
Mac x64 DMG version: http://download.xnview.com/XnViewMP-068-mac.dmg
If you have always the problem, please send me your xnview.db
maximcapra
Post by maximcapra »
i had the same error and i just wanted to tell you, the above version fixed it! thanks!
