Hi All..
Just installed the software as a replacement to Nuance's PaperPort and I'm so happy i found it... so much easier to use and cleaner..
EXCEPT>.... My fax software brings in my faxes as .TIF files.. and for some reason XnView cannot open them ... i have to right-click and Open With Advanced Program.. .
Not sure how to fix this and was hoping someone could help out..
Any thoughts?
RONNY
Error Reading the File .... *.TIF
Re: Error Reading the File .... *.TIF
rbergmandc1
hows this?
- Forum Librarian
Clo ([url=http://newsgroup.xnview.com/viewtopic.php?p=68105#p68105]Problem opening certain .tiffs[/url]) wrote:It works only when the box Option >> Read/Write [×] Ignore read errors is ticked ! Or else, nope.
[url=http://www.awaresystems.be/imaging/tiff/astifftagviewer.html]AsTiffTagViewer v2.00[/url] ([color=green]Fax 6-3-2013 16;57;10.tif[/color]) wrote:Code: Select all
#### Page 1 of 4 #### SubFileType (1 Long): Page ImageWidth (1 Short): 1728 ImageLength (1 Short): 2142 BitsPerSample (1 Short): 1 Compression (1 Short): Group 3 Fax (aka CCITT FAX3) Photometric (1 Short): MinIsWhite FillOrder (1 Short): Lsb2Msb StripOffsets (1 Long): 234 Orientation (1 Short): TopLeft SamplesPerPixel (1 Short): 1 RowsPerStrip (1 Short): 2142 StripByteCounts (1 Long): 108789 XResolution (1 Rational): 200 YResolution (1 Rational): 200 Group3Options (1 Long): 0 ResolutionUnit (1 Short): Inch PageNumber (1 Long): 0 #### Page 2 of 4 #### SubFileType (1 Long): Page ImageWidth (1 Short): 1728 ImageLength (1 Short): 2134 BitsPerSample (1 Short): 1 Compression (1 Short): Group 3 Fax (aka CCITT FAX3) Photometric (1 Short): MinIsWhite FillOrder (1 Short): Lsb2Msb StripOffsets (1 Long): 109252 Orientation (1 Short): TopLeft SamplesPerPixel (1 Short): 1 RowsPerStrip (1 Short): 2134 StripByteCounts (1 Long): 107747 XResolution (1 Rational): 200 YResolution (1 Rational): 200 Group3Options (1 Long): 0 ResolutionUnit (1 Short): Inch PageNumber (1 Long): 0 #### Page 3 of 4 #### SubFileType (1 Long): Page ImageWidth (1 Short): 1728 ImageLength (1 Short): 2136 BitsPerSample (1 Short): 1 Compression (1 Short): Group 3 Fax (aka CCITT FAX3) Photometric (1 Short): MinIsWhite FillOrder (1 Short): Lsb2Msb StripOffsets (1 Long): 217228 Orientation (1 Short): TopLeft SamplesPerPixel (1 Short): 1 RowsPerStrip (1 Short): 2136 StripByteCounts (1 Long): 106964 XResolution (1 Rational): 200 YResolution (1 Rational): 200 Group3Options (1 Long): 0 ResolutionUnit (1 Short): Inch PageNumber (1 Long): 0 #### Page 4 of 4 #### SubFileType (1 Long): Page ImageWidth (1 Short): 1728 ImageLength (1 Short): 2142 BitsPerSample (1 Short): 1 Compression (1 Short): Group 3 Fax (aka CCITT FAX3) Photometric (1 Short): MinIsWhite FillOrder (1 Short): Lsb2Msb StripOffsets (1 Long): 324421 Orientation (1 Short): TopLeft SamplesPerPixel (1 Short): 1 RowsPerStrip (1 Short): 2142 StripByteCounts (1 Long): 90969 XResolution (1 Rational): 200 YResolution (1 Rational): 200 Group3Options (1 Long): 0 ResolutionUnit (1 Short): Inch PageNumber (1 Long): 0
rbergmandc1
perfect.. that seems to have fixed it.. thanks much..
Just another quick question.. how do I make it so when looking in a folder it doesn't show the FOLDER THUMBNAILS and only shows the files?
- Forum Librarian
You have to deactivate the checkbox(es) for Folders in Tools » Options... » File List » File List.rbergmandc1 wrote:how do I make it so when looking in a folder it doesn't show the FOLDER THUMBNAILS and only shows the files?
