Info pane
twocities
Info pane
Post by twocities »
This is a fantastic program, thank you all, I love it.
I have many questions, but mainly, "How do I bring up the Info pane?" The Data pane has a Show item, the Info pane seems to appear mysteriously.
Regards,
twocities
Re: Info pane
By clicking in a pane, you have a context menu to show/hide any pane
m.Th.
Re: Info pane
Post by m.Th. »
Pierre means that you must right-click on the title of any pane in order to see the popup menu with the other available panes.
If you cannot see the title of the panes, go to View menu and check 'Show Title of Panes' option there.
m. Th.
twocities
Re: Info pane
Post by twocities »
Thank you, that makes things much easier.
twocities
