Sync bug from 0.64 persists
Kenny96
Post by Kenny96 »
Browser's synchronization with categories still doesn't work on linux:
If you have images with the same tag in different folders you are unable to navigate by categories, because when you close a pictures the browser goes to show you the folder where is the picture and not the categorie.
http://newsgroup.xnview.com/viewtopic.p ... 67#p117167
m.Th.
Re: Sync bug from 0.64 persists
Post by m.Th. »
Do you have in the Tools | Settings | Interface | Interface the "Synchronize browser view" UNchecked?
m. Th.
Kenny96
Post by Kenny96 »
The bug is related to the sync option, if I disable it, I haven't the bug but I lose this important feature. I think that the browser's view synchronization is intended to work also with categories's selection.
Generally I select a category, I open an image and start to move forward to the next 10 or 20 images, then I close the preview and, without the synch option, I'm forced to search in the browser window untill i find the last photo that I have looked, before I can continue the research.
