Linux: Data pane not completely scalable
Klaas
Post by Klaas »
Here is a small bug under Linux (Xfce desktop, in case this is of importance). I first noticed it with 0.67, it persists with 0.68.
The data pane is not fully scalable any more.
When I roll the mouse cursor over the pane's border it becomes a double-pointed arrow:
Nevertheless I cannot drag the pane's border further to the left in order to reduce the data pane's width (and thus to enlarge the preview area...) - I just can drag it further to the right. So there appears to be a certain (unappreciated) minimum width of the data pane.
This does not happen under Windows, so I suppose this is a bug and not a feature...
Re: Linux: Data pane not completely scalable
you had not this bug in 0.64??
Klaas
Post by Klaas »
Pierre,
I'm almost absolutely sure the bug appeared with 0.67...
I use XnViewMP under Linux and Windows since years on a daily basis, and I never had such a broad data pane before... And I use to experiment quite a lot with different layouts - I'm sure I would have noticed the bug if had it existed earlier (just like I immediately noticed it in 0.67) .
ok, right, it's new but i don't remember why i have changed that...
See Issue 393 for current status and details.
Klaas
Post by Klaas »
Fixed in Version => 0.69
(And really: it is a minor bug, I already got used to it.)
