Install of XnView 2.22 fails libmcl-6.0.1.dll and libmpg...
ser
Post by ser »
Hello
Installation (from fresh downloaded Xnview_win_full.exe Ver. 2.22) fails with error message about "libmcl-6.0.1.dll". Then I ignore skip the message, a second failure about "libmpg-2.4.0.dll" appears.
As can be seen in attached screenshot, there is something wrong in the installation-ZIP as well.
Both DLL are locaeted in theAddOn-folder.
Appears on Windows 8.1 Home Premium 64bit as well as on Winows 7 SP3 Home Premium 64bit
I would be very happy about the problem to be solved.
Many thanks, SER
Re: Install of XnView 2.22 fails libmcl-6.0.1.dll and libmpg
Strange i have n problem, try to download it again?
ser
Post by ser »
xnview wrote:Strange i have n problem, try to download it again?
Thanks for reply. Yes, I tried several downloads with Firefox.
Right now, I was using the IE instead of Firefox for downloading. The Installation of the *.exe was successfully now! The Unpacking of the IE-downloaded ZIP was OK as well.
Strange again. The file size of both downloaded file types are also the same. But MD5-Checksums are different.
Probably a problem of Firefox instead of XnView?
Many thanks, SER
oops66
Post by oops66 »
... As I said here before, ... maybe a MD5 checksum is needed for each XnView(MP) versions releases? (to avoid this kind of problem)
http://newsgroup.xnview.com/viewtopic.p ... 77#p119777
