10-bit YCbCr DPX files
mike
Post by mike »
It appears that XnView does not correctly display DPX files with the following header values:
Image element descriptor: 100 (Cb,Y,Cr - 4:2:2 SMPTE 125M)
Component Data packing: 1 Filled to 32-bit words
Bit depth: 10.
Files are big endian.
I have sample file if needed.
Re: 10-bit YCbCr DPX files
mike wrote:It appears that XnView does not correctly display DPX files with the following header values:
Bit depth: 10.
Fixed in 1.68.1
