Hello
when I type Shift+E for menu window "Einstellen" (german version) there is only the title bar and nothing else.
I used this functions sometimes so that I am sure that it worked. What could be the reason that it does not work anymore?
I'm using XnView 2.20 with XP Prof SP3.
Menu window is gone
Re: Menu window is gone
In you xnview.ini, please remove line with geometryH & geometryW in [AdjustDlg] section
xntest
Thank you for quick answer, Pierre.
I have deleted the above mentioned lines.
After starting XnView the Adjust Dialog was shown in its full size but only for one time.
After closing and opening it again the dialog window had only its half height.
After closing and opening it more times there was only shown its title bar again.
The deleted lines in the xnView.ini were added again by XnView.
you have the last version?
