Can you make the font bigger on the overlayed text with this batch process.
At present I have 1.99 and wonder if the newer versions have bigger fonts
increase font size on Tools/Batch Processing/Add text
mark pigott
Re: increase font size on Tools/Batch Processing/Add text
If you click on the Transformations > Add Text > Font -- 'Choose' button you can select a font, and when you do so the available point sizes for that font are displayed: DejaVu Sans, for example, is available in point sizes up to 72 ...mark pigott wrote:Can you make the font bigger on the overlayed text with this batch process.
mark pigott
Thanks.
If there a way to save these settings as default?
You can save the overall Batch Processing actions as a script that can reloaded later, using the Script -- Save... (xbs) or Script -- Export... (bat, cmd) buttons to save in one of those formats, and the Load... button to reload the script later.mark pigott wrote:Is there a way to save these settings as default?
Edit:
XnConvert has an option to reload the last script used automatically when it opens, which might be useful if the features you need are all supported...
The XnConvert Preview feature might also be useful to set up the text effect you need.
mark pigott
Thanks for your help. Everything is quite clear to me now!
