file associations doesnt work in Windows 8.1 (XnViewMP 0.68)
harumscarum
Post by harumscarum »
1. settings - integration - "run the file association tool" - no effect, nothing starts
2. run Associate files with XnViewMP.exe manually and set all associations, but nothing happens at the end
XnViewMP 64bits, always run As Administrator
any ideas how to fix that?
Re: file associations doesnt work in Windows 8.1 (XnViewMP 0
perhaps a problem in your registry, try to remove the HKL\Software\XnViewMP key
