XnViewMP 0.68 crash and exit when try to browse a folder
maximiliano
Post by maximiliano »
Have a usb disk with lots of folders and pics.
When try to enter inside one specific folder, XnViewMP closes and exit (no pop up window). The others folders have no problem.
Find a .dmp file with the path of this folder inside, but don't know how to attach the file, or if I have to rename it, or copy and paste the content of the dmp file here.
Thanks
Re: XnViewMP 0.68 crash and exit when try to browse a folder
maximiliano wrote:Find a .dmp file with the path of this folder inside, but don't know how to attach the file, or if I have to rename it, or copy and paste the content of the dmp file here.
You can either post the text contents inside [code][/code] tags or compress the file to a ZIP archive and upload that as an attachment.
maximiliano
Thank you XnTriq. Attach the zip file.
The path I can't acces is H:\FOTOS\2010 11 NOV
2eb474c3-4f6c-45e9-a198-2757c8dcec10.zip
(16.09 KiB) Downloaded 205 times
is it possibe to have the content of folder?
maximiliano
Yes, no problem. Have 138 pictures, 158MB.
The problem was solved after I renamed all the pics with Windows Explorer.
m.Th.
Post by m.Th. »
Hummmm.....
Perhaps did you have some special characters in the file names?
m. Th.
maximiliano
Maybe, my languaje is spanish. Sorry but don't remember.
Have to close this topic or do something more?
