XnViewMP 0.68 - button delete all cached dirs not working
Seryi
Post by Seryi »
1) XnViewMP 0.68 x64 (Win7 x64 rus) - button delete all cached dirs not working;
2) Also semantic error in russian translation - "Base path of your pictures" not must be "Расположение кэша эскизов" but must be "Путь перед основной папкой" or something else.
m.Th.
Re: XnViewMP 0.68 - button delete all cached dirs not workin
Post by m.Th. »
1. Do you speak about Tools | Settings | Database | [Delete All] ?
2. What means "not working"? What do you expect to do and what you see that it does?
m. Th.
Seryi
Post by Seryi »
1. Yes.
2. I guess that should disappear all the rows in the window, as in the case with a button "delete" removed one line, but nothing happens.
P.S. Rather, only the size of the caches are cleared. Then, logically, the button should be called "Clear all" / "Очистить все".
Welcome to the forum, Seryi :-)
Seryi wrote:2) Also semantic error in russian translation - "Base path of your pictures" not must be "Расположение кэша эскизов" but must be "Путь перед основной папкой" or something else.
Seryi wrote:P.S. Rather, only the size of the caches are cleared. Then, logically, the button should be called "Clear all" / "Очистить все".
Thanks for your suggestions. Please repost them in “** Русский - Russian”.
Seryi wrote:And another question: when the show 4 icons for video files in most cases show a single icon and several with four icons in a folder with lots of videos. Is this normal?
I've created a separate topic for this question: “XnViewMP 0.68 - 4 icons for video files
helmut ([url=http://newsgroup.xnview.com/viewtopic.php?p=210#p210]Rules and Guidelines[/url]) wrote: - One problem/question per post.
Please start one topic per problem/question. This will make answering easier.
