thumbnails not visible <SOLVED>
gcobut
Post by gcobut »
Hello
I'm running XNView 2.22.
I've a strange issue: in "explorer" mode, XNView does not see any pictures anymore.
I know the picture are there (I can display them in Windows explorer) but XNView says "0 objects".
Please note that no subfolders are displayed either :-(
I tried de-installing, cleaning the registry, re-installing, no result.
Thanks for any clue.
Re: thumbnails not visible
Do you use Filter>Custom?
gcobut
Post by gcobut »
Oh my God !!!!
Many thanks for this trick, Pierre !
I was not aware that a filter on "tagged files" was active; so nothing was displayed nowhere and I was getting crazy...
I changed it to "view all files" and my good old XNView is working again!
Many thanks!
