Batch Rename tool is missing "Sort" option
gonzos-revenge
Post by gonzos-revenge »
StephanP wrote:It appears to me that the Batch Rename tool is missing the "Sort" option.
In XnView (classic) I frequently applied the sort option to have the files sorted by EXIF Date before renaming and numbering.
This option is no longer available, Or should I do the sorting beforehand in the Explorer and THEN do the Batch Rename?
Have to bring it up again.
This is my standard procedure when renaming my jpg files and it´s the only reason for me to stay with 2.22 on my machine.
Still missing in Version 0.68.
Re: Batch Rename tool is missing "Sort" option
you can sort by exif date
gonzos-revenge
Re: List of missing features (compared to XnView Classic)
Call me a little bit stupid, but where is the sort option in batch rename.
1st screenshot XnViewMP0.68, 2nd screenshot XnView2.22
m.Th.
Post by m.Th. »
Call me a little bit stupid...
No, I won't do that.
However, I might thinking about it if you DO NOT go to XnView MP - Suggestions forum and (re)post this as a minor feature request. :)
It will get lost here.
However you CAN workaround this limitation, hence no real need for the Classic version, by sorting the files/thumbs in the Thumbs pane, before triggering the Rename dialog. Showing the Sorting Header helps a ton here. Go to View | Sort by... | Show Header in order to display it.
m. Th.
gonzos-revenge
feature request
I´m missing the "sort" function in batch rename in XnViewMP like shown in the screenshots below.
Would be nice to have it back in one of the next versions.
PP0815
Re: feature request
Post by PP0815 »
As long as this is not implemented you can simply sort the files in the viewer mode. The file list in the batch rename window represents the sort order from the viewer mode.
und auf deutsch:
Solange die Funktion nicht implementiert ist (falls sie denn überhaupt einzug erhält) kannst du einfach im Betrachtermodus die gewünschte sortierung wählen. Die Sortierung der file liste in der Stapelumbenennung entspricht nämlich der sortierung im Betrachter modus.
