0.68 JPEG unable to set 100% quality
fireattack
Post by fireattack »
I've already read this thread: http://forum.xnview.com/viewtopic.php?f=79&t=23119
The mod there said XnViewMP used IJG's lib to convert JPEG, I'm not sure if it's still the case.
If we're still using IJG's implementation, IJG's lib does have quality setting of 0-100, instead of 0-99:
(Copied from usage.txt document downloaded from http://www.ijg.org/)
-quality N[,...] Scale quantization tables to adjust image quality.
Quality is 0 (worst) to 100 (best); default is 75.
(See below for more info.)
If not, why 99? Most of other software just uses 0-100, including old XnView.
Thanks for your great product!
Re: 0.68 JPEG unable to set 100% quality
See Issue 431 for current status and details.
