BUG: Blurred image inside of XnView (Fit to Screen)
Subtek
Post by Subtek »
Hey,
today i found one not really good thing about XnView. it is quite important matter for image viewer.
when images getting smaller in XnView (they are fitted to screen), pictures are getting explicitly blurred..
i found on comparison with ACDSee 2.4 (old but ultimate picture viewer) that when my image is bigger than my monitor screen and i have enabled option "fit image to screen" than images are getting obviously blurred - they are not sharp! when i click on "*" to view picture in original size than image goes correctly sharp of course as it is in original. but when any image is reduced to 'fit the screen' modus than images suffer with this problem..
i did compare it with "ALT+Tabulator" with ACDSee (of course also in modus 'fit image to screen') and result is really really prominent..
i guess that your drawing core works bad for this temporarily type of conversion. something goes wrong in calculation for each picture..
so i please you to fix it in upcomming update;)
many thanks.
let me know
Alex
Re: BUG: Blurred image inside of XnView (Fit to Screen)
You can disable High quality zoom in Tools » Options... » View » View.
