I used to use CTRL-SPACE in ACDSEE to select multiple files from a gallery after I preview them.
I would like to do the same thing in xnview but can't figure it out.
Basically I would like to review ALL images with the LEFT/RIGHT keys. And Select the ONES I like with a button. Then, do a Ctrl-C and copy them elsewhere.
That way, I can quickly select the images that I like from a huge gallery after I review them in the preview window.
Best regards
Multiple Image Select in Browser View ?
Re: Multiple Image Select in Browser View ?
you can the tag system Ctrl+T
- Forum Librarian
jvittori ([url=http://newsgroup.xnview.com/viewtopic.php?p=120218#p120218]easy delete / sort out / mark pictures while slideshow?[/url]) wrote:You can tag every selected image as the slideshow goes on. Finally, you alt+c "tagged files" to the folder you want. For tagging, you can press "space" or "insert". I´d pick "insert" up as "space" will you move forward. Hope it helps.
nh2user
ok, Insert works...
Will the images stay tagged after I copy ? Or will they stay tagged if I go in the same gallery some other time ?
or will the count revert back to nothing ?
you have options>Thumbnails>Icon info -> Tagged files
