Creating a video from a XnView slide show
Lendee
I bring up the slide show from the browser, I select all pictures in the folder and everything is OK, I select the audio for the slide show and play the slide show and all is OK, I select create video, lower right corner of slide show screen and get create video slide show screen I select WMV for the format and the other settings are fixed size, width 640 x height 480 and fit image to video size. I select create and encoding is shown for all pictures in the video and then states encoding ended. I go to my folder and there is a WMV there but when played either by windows or XnView browser I only get one frame of video 84.0kb of information. What am I doing wrong?? I have done this in the past and have the WMV to prove it but can't seem to use it again any suggestions would be more than grateful.
Re: Creating a video from a XnView slide show
and with another codec?
