drag and drop - copy/move does not work correctly
TD
Post by TD »
I have two problems with drag and drop in XnView MP:
Under Windows:
If I drag a file with the mouse to another folder on the same disc, it will be moved.
Now, when I hold down "Ctrl" at the same time the cursor should change to copy the file.
In XnView classic it is like this, but in XnView MP the cursour does not change and the file will be moved.
Under Ubuntu:
The behavior should be like under windows, but if I drag a file with the mouse to another folder on the same disc, it will be copied.
Regards,
jefftrip
Re: drag and drop - copy/move does not work correctly
Post by jefftrip »
Using xnviewmp 0.68
I have the same problem, that under linux (mint xfce 15) drag and drop (of a file or folder) in the browser is a copy rather than move (even on the same disk). I have to keep deleting the originals. By the way the files are on an NTFS disk.
I also had this problem under windows XP. In the windows case I got an error message: Copy warning, cannot remove source. However that was on a computer that had not been updated for years. Works OK on my windows XP laptop.
Great program apart from that!
