often I quick convert some selected images to an other format. In the past the UI automatic closed, so I was sure, the job is done. Now the UI stay open. Is it a bug or is it an option now, that can be changed?
Regards,
Micha
PS: I doesn't update since a long time and after I updated to the last version I found this kind of workflow breaks now.
Bug: Batch Proscessing UI doesn't close after Batch is done
Micha
Re: Bug: Batch Proscessing UI doesn't close after Batch is d
you have a checkbox 'close dialog'
Micha
So easy.
Seems to be reset by the update.
Thank you,
Micha
Thank you,
Micha
