ZIP Pack Plugin - some suggestions
Peter2
Post by Peter2 »
I tried this plugin the first time - some small remarks:
a) The "save as .." dialogue has the wrong title. There is "Save as (Ctrl+Shift+S)..." - that's wrong, because it is the original "save as image - command".
b) The edit field for filename is empty. It would be fine if the default is displayed as "<Filename>.zip"
c) "Save as ..." to an existing ZIP displays the standard dialogue: "File already exists. Do you want to overwrite?" That's also wrong, because the current file is added to the ZIP and does not replace the ZIP.
Would be fine if it could be improved.
Peter
