Related to this and this.
1. have a folder named c:\Temp1
2. Assign some categories to some photos in it
3. Rename the folder to c:\Temp2 in the Folders Tree
4. Go to see the photos from c:\temp2 are 'unassigned'
Expected: The categories of the photos should go with the photos (be sure to NOT save the metadata in file/sidecars - for ex. use RAW files)
Actual: the photos from c:\temp2 are 'unassigned'
Notes: In Settings | Database there are two folders: c:\Temp1 and c:\Temp2 while it should be just one: c:\Temp2.
Since c:\Temp1 is successfully renamed to c:\Temp2, this means that c:\Temp1 doesn't exist anymore.
Renaming folders blows up the Keywords/Categories
m.Th.
m. Th.
Re: Renaming folders blows up the Keywords/Categories
and if you rename the folder in thumbnail view?
m.Th.
It seems that it is working ok from thumbs view. However is rather difficult to reproduce because it seems that it needs to have a folder which needs time to be scanned (many and/or big files?) and/or to be on a LAN(?).
m. Th.
