Visual feedback on "lossless rotate"
PP0815
Post by PP0815 »
is there any chance to implement a visual feedback (a "how much percent is done already" bar) on the "lossless rotate by Exif oriantation" feature. When I use it on a lot of images the program looks like its dead (I know its not but till xnview is done the only thing that happens is that the cursor change to the windows sandclock. No way to know how long it will take for the action)
thanks
m.Th.
Re: Visual feedback on "lossless rotate"
Post by m.Th. »
You can already do that in Batch Convert (Ctrl+U) which has a progress bar.
However I think that you speak about the separate buttons/menu entries which program have. In this case, well... I think that these were designed for small batch operations. But if it easy for Pierre to do it, it will add to the program's value/easeness to use.
m. Th.
PP0815
Post by PP0815 »
Thanks. I wasn't sure if the rotate in the batch menu is lossless.
