[2.22] Creating PDF with non-std filenames
eL_PuSHeR
Hello.
Some days ago while creating a PDF file some of the source JPEG filenames had got Spanish characters in them. They were 10 source files. The resulting PDF file was 7 pages only. XnView had just skipped those 3 files with special characters in its filename (vowels with "tilde" - á é í ó ú). Is this a known issue? is it an Unicode issue?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
Re: [2.22] Creating PDF with non-std filenames
i think that your files use unicode
eL_PuSHeR wrote:Some days ago while creating a PDF file some of the source JPEG filenames had got Spanish characters in them. There were 10 source files. The resulting PDF file was 7 pages only.
There is an open request to add multi-page PDF output as a batch convertion option in XnViewMP and XnConvert, which support Unicode and are also cross-platform...xnview wrote:i think that your files use unicode
eL_PuSHeR
Thanks for the replies, gentlemen. Yes I am aware XnViewMP supports Unicode, but I will stick to XnView classic until the MP version is mature.
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
Well, when output to a multi-page PDF is added to XnViewMP you could use it to create your PDFs with Spanish characters, and continue using XnView 'Classic' for everything else...eL_PuSHeR wrote:... I am aware XnViewMP supports Unicode, but I will stick to XnView classic until the MP version is mature.
MultiPage create exists in XnViewMP 0.68cday wrote:Well, when output to a multi-page PDF is added to XnViewMP you could use it to create your PDFs with Spanish characters, and continue using XnView 'Classic' for everything else...eL_PuSHeR wrote:... I am aware XnViewMP supports Unicode, but I will stick to XnView classic until the MP version is mature.
Not for single image files to a multipage PDF output file, or am I missing something?xnview wrote:MultiPage create exists in XnViewMP 0.68
In Batch convert?
Single image input files to a multi-page output file was part of m.Th's recent request.
If not currently supported that would be a very useful addition...
oh ok, not yet in batch convert
And no equivalent in XnViewMP to XnView Classic's Tools > Multipage file > Create either?xnview wrote:oh ok, not yet in batch convert
So currently no way to create a multipage file from files with Unicode characters in XnView or XnViewMP...
no you have it Create>Multipage filecday wrote:And no equivalent in XnViewMP to XnView Classic's Tools > Multipage file > Create either?xnview wrote:oh ok, not yet in batch convert
In XnView Classic? Sure, but not to create from files with Unicode characters...xnview wrote:you have it Create>Multipage file
In XnViewMP?
Not in the Tools menu, and I don't see it anywhere else...
Someone please tell me if I'm missing something...cday wrote:So currently no way to create a multipage file from files with Unicode characters in XnView or XnViewMP...
in browser menu
Thanks!xnview wrote:in browser menu
In XnViewMP and XnView Classic in the browser menu (which does seem logical...
So eL_PuSHeR could use XnViewMP now to create multi-page PDF files from images with Spanish characters in the file names, and continue using XnView Classic for everything else...
eL_PuSHeR
I think it's easier to rename those filenames first, instead of using two software.
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
