Hi!
Although my heart screamed at me not to install XnViewMP my brain told me that if didn't work I could always uninstall MP und then keep using XnView. Once again I must realise that my heart is smarter than my brain. Neither MP nor Classic worked after the install of MP. An uninstall of MP didn't change that. A removal of Classic followed by a cleaning af the registry and a reinstall after a reboot haven't changed that.
XnView starts ok. I can choose a function, and that's it! Afterwards it just stops working. I have been very happy with XnView and I really don't want to change to another program - and I'm not reinstalling Win7 for XnView - just to find out it didn't work...
Any suggestions how I get it to work again?
I'm using Win 7 64 Home Premium with 8 GB RAM
Nox
XNView crashes
Re: XNView crashes
you have the same problem with XnView & XnViewMP??
Do you have tried to change the startup folder?? Perhaps a file that crash XnView...
Nox
Re: XNView crashes
Hi!
The problem did not occur until I installed XnViewMP and both programs had the same problem.
Uninstall of both XnViewMP and XnView and a reinstall of XnView did not help.
Since I reinstalled XnView the startup folder shouldn't be a problem. Anything I need to delete after the uninstall?
At the moment I can use XnView as WindowsViewer - that's it. Anything else and the program crashes.
Re: XNView crashes
i think that XnViewMP is not the problem, do you have tried to rename the xnview.ini?
