XnViewMP crashes after dir delete
bdesmet
Post by bdesmet »
Probably a bug which appears in XnViewMP 0.68 for Mac:
I am using Mac OS X 10.8.5
- Go to Browse Modus
- Go to the Folder view in the data pane
- Choose a directory
- Right mouse click and choose "Delete" from the context menu
- Confirm the delete.
- The directory and all its contents will effectively be removed, but the application crashes always directly afterwards.
If interested, I could send you a report of the crash provided by Darwin kernel.
Best regards,
Brecht
