Probably a bug which appears in XnViewMP 0.68 for Mac:
I am using Mac OS X 10.8.5
- Go to Browse Modus
- Go to the folder view of the Data Pane
- Create a new subdirectory under, for example /Users/user/Pictures (by right clicking and choosing the "New Folder" option in the context menu)
- Click another directory in the folder view
- Choose one or more pictures and drag them to the newly created directory
- The files will not be copied (nor replaced). Clicking the newly created directory has no effect. Furthermore, the symbol left from the directory name now indicates that there is a subdirectory. However, there isn't one.
- This bug appears always.
Best regards,
Brecht
XnViewMp for Mac file copy failure
