XnView MP 0.68 - Assign a Tag from "Right Click" / Categorie
Roumano
Post by Roumano »
On my Linux version of XnView MP 0.68
I can't assign a "parent" Tag from "Right Click" / Categorie
I have hirechical tag like :
Photographie
People
Portait
I can't assign to People as a sub-tag exist & click on people do nothing.
Re: XnView MP 0.68 - Assign a Tag from "Right Click" / Categ
you means select all parent from a category?
m.Th.
Post by m.Th. »
Roumano wrote:Hi,
Photographie
People
Portait
IIUC you use the right-click menu to (try to) assign tags/categories, right?
Naturally there isn't supported. You can use the Categories Pane (the place where you created the tags in first place) and/or assign shortcuts to your tags.
m. Th.
