Mac OSX - squashed 'Enhance colors'
budz45
Post by budz45 »
On the Mac OSX (I tested in a shop, I tested iMac 27inch screen 2560x1440)
please fix the small issue of the Window width of the 'Enhance colors' window....Make it's window wider
see attached photo
m.Th.
Re: Mac OSX - squashed 'Enhance colors'
Post by m.Th. »
On Windows the window is resizable and its dimensions together with its position are saved. So a simple resize as you need is enough.
Also, from your photo, the XnView main window together with the 'Enhance Colors' window is badly skewed. Bigger on the right and smaller on the left. Uneven and un-parallel margins. Very, very bad. On Windows all windows are in clean, rectangular shape with parallel margins.
Switch to PC. :mrgreen:
m. Th.
budz45
Post by budz45 »
"switch to PC"
:D I am already and always have been a PC user (from Windows XP to Windows 7, soon I will get Windows 8.1 too).
As mentioned in the original post, I was only running a test of XnViewMP on a store's iMac for sale.
