No jpg thumbnail in browser
montu
Post by montu »
When I use the browser window and set the file-filter to PICTURE no jpg file is shown but my RAW.
Switching the filter to ALL or user-defined (with jpg enabled in the optins) brings back the jpgs thumbnails.
I'm using Windows 7 64 bit and XNview 2.22.
Don't think that I have this problem with 2.20 but I don't have the installation file for the old version to proof.
Re: No jpg thumbnail in browser
i can't reproduce, which view mode do you use?
montu
Post by montu »
Hello Pierre,
sorry for my late reply, I'm busy the last days.
I have this problems in Browser mode.
I now figuered out when the problem happens and it isn't only affected to jpg but to all extensions.
When I add an file extension of an image to custom file,
it is not shown up any longer when i choose images at the filter in browser mode.
The same thing happens to an video file.
I don't try other extensions.
Hope that this helps you.
montu
Post by montu »
Any news on this or should i tape a video?
I can repoduce this bug on any machine with any extension.
montu wrote:Any news on this or should i tape a video?
right, a bug
montu
Post by montu »
Thanks, for confirming this.
montu
Post by montu »
Hello Pierre,
thanks a lot for the great update to 2.30.
The problem is gone but only for image extensions, but still exist for video, audio and archive-files.
I think also other none image extensions will affected.
