I don't want to find all similar files in the folder. I want to find similar files of just 1 file. Please add the function of adding 1 file (not just folder as now) and find similar files of that file in specific folder. Thank you.
It should be:
Choose file or folder to find similar files.
If folder: as now
If file: choose folder to find similar files
And I think I found bugs. When I tried to find similar files the result is the same images. Same data, same name, same folder. So why do I need to find itself?
Find similar files - I want to find similar file of 1 file
byomartin
