View->Layout->Free not working
pictotaler
Post by pictotaler »
I'm new to the forum (I think), but I've been using XnView since probably the very beginning, so kudos to the maker :)
I've just switched to XnViewMP, and I find layouts a bit confusing. If I understand well (and there I can say that in all these years, I've often thought I'd pay a reasonable sum to have a complete, up-to-date Help/Manual for XnView), there are layouts 1-8 and filmstrips 1-2, which are hardcoded, and then there are layouts A-E which are customizable. Then there's the "Free" item under View->Layout menu, which I guess means "Layouts A-E". It is confusing because it has a checkmark, but can't be unchecked, which is the very purpose of checkmarks...
What I was trying to do is LOCK my custom "A" layout so that I don't move panels around by accident when clicking clumsily in them, which happens a lot... Am I correct in thinking this locking can't be done? If that's the case, having all Layouts (1-8 and A-E) under the View->Layout menu (and in the "Filelist toolbar" as well) and a real, working checkmark item labelled "Lock" instead of "Free" would be a suggestion...
m.Th.
Re: Layouts a bit confusing
Post by m.Th. »
It seems that the layout engine has some problems.
Normally, the layouts from 1 to 8 and the two filmstrips are just some predefined configurations for the same layout engine underneath.
The 'Free' check-box is supposed to (UN)lock the free movement of the panels around.
The Layouts A-E are custom made layouts.
In this way it SHOULD be.
But indeed the things are a little bit fuzzy there.
However, how do I work:
I make my layout as I wish with "Free" option checked.
I save it as "Layout A".
I take care how I use the mouse. :D
If something happens (accidentally or intentionally) I restore the "Layout A".
m. Th.
pictotaler
Thanks,
I'll try to post a bug report.
pictotaler
<--// Moderator's note: Topic #30613 and #30618 have been merged. //-->
