This is probably too silly to consider seriously, but It's something I can't help but notice.
XnView is one of the applications I install every time I rebuild one of my PCs, which I do fairly frequently. In the install process I remove the check to Create a desktop icon and I remove the icon to Create a Quick Launch icon.
Then the first time I run XnView the very first thing I do is remove the desktop icon that is created by the initial setup. Is there a reason to offer the yes/no choice for the desktop icon during setup if it is going to be installed any way when the program is first used?
Icon to Desktop
- Forum Librarian
Re: Icon to Desktop
Do you get the “welcome screen” when you run XnView for the first time, DudleyK?
