Is there any way to get a webpage template that allows clicking on the right side of an image, it goes to the next image and clicking on the left side goes to previous image?
I know that the Previous | Thumbnails | Next buttons exist on the top of the templates, but quite often the images are larger than a whole screen, and you usually have to scroll down to see some of the image. Then, to advance to the next image or go back to the previous image, you have to scroll back up to get the previous/next buttons. It would be much easier if you didn't have to scroll back up if you wanted to advance/return.
Anyways, let me know if this is possible to get implemented.
Previous/Next by clicking on image
- Forum Librarian
Re: Previous/Next by clicking on image
Some of the “Visuddhi” templates come with (an old version of) Lightbox2. Is that what you're looking for?
