I got a HTC One Mini 2. I'm using Win7 64bit
XnView can't display the pictures taken with the camera. Like you can see in the attachment the pictures are displayed as "textfiles". There is no difference whether I copy the pictures to my PC or I browse through XnView to the folder on the SDCard. I got the same result if I'm using the "Faststone Viewer"
Opening the pictures with the build in "Windows Photo Viewer" or GIMP is no problem.
Does anybody got any ideas?
TiA
ben.the.king
Pictures from an HTC One Mini2 can not be displayed
ben.the.king
Re: Pictures from an HTC One Mini2 can not be displayed
You are using XnView Classic and not XnViewMP? The plug-ins for XnViewMP are 32-bit and not usable on the 64-bit version, I believe, although that may not be relevant.ben.the.king wrote:I got a HTC One Mini 2. I'm using Win7 64bit
XnView can't display the pictures taken with the camera. ... I got the same result if I'm using the "Faststone Viewer" ... Opening the pictures with the build in "Windows Photo Viewer" or GIMP is no problem.
Could you upload a sample file for Pierre to examine -- 1MB is the current attachment size limit, and you will probably have to place the file in a ZIP or RAR archive to upload it. Or upload a file to the cloud and provide a link...
please send me some samples?
