Good afternoon...
Moved from topic How to: Categories Management - Categories Panel
I'm working through my catalog of photos, hoping this time to finally get it right. One thing I have an issue with in XnView MP is the Category Sets - Assigned interface. I would prefer if it showed me the categories assigned in a tree rather than an alphabetical series of labels/buttons. Since some of my photos already have categories from other photo-managers it's tough to know if the category that is there is the correct one (in the correct hierarchy) or an old one without a hierarchy.
Also, since there are issues with XnView MP applying parent categories consistently it would also help double-check that all categories are properly assigned.
Thanks,
Feature Request: Assigned Categories - Category Sets
- schultzter
- Contact:
Version 0.72 x64 (Dec 19 2014) on Arch Linux
Headed for the second star to the right and straight on 'til morning...
Re: Feature Request: Assigned Categories - Category Sets
isn't Data pane > Categories > (assigned categories checked) what you are wanting?
Build Debian http://dquinton.github.io/debian-install/
- schultzter
- Contact:
With that I see both that is assigned and what isn't. And if you have a lot of categories (like I do) then there's a good chance you'll miss something this checked/un-checked that shouldn't be.
What I'd like is for Category Sets > Assigned to show the the assigned categories in their hierarchy.
maybe a toggle button on the categories pane is needed too: All/Applied ??
so in cat. sets, under Applied, something like... animal:dog places:home
- schultzter
- Contact:
I think Digikam has something like that. That would work too. But since there's already and Assigned tab in XnView MP I would just re-format that.orbspider wrote:a toggle button on the categories pane
+1 for showing the full path of set categories instead of categories in alphabetic order.
Vertébré|Mammifère|Périssodactyle|Equidé|Cheval instead of Cheval Equidé Mammifère Périssodactyle Vertébré mixed with other categories.
I'm also missing the option to have all parent categories selected automatically when I select the leaf one (Cheval in the following example):
Vertébré
Mammifère
Périssodactyle
Equidé
Cheval
The option "Don't export" is then used to not export the root ones if necessary while I can still use Vertébré as a filter.
Thanks
Philippe
Vertébré
Mammifère
Périssodactyle
Equidé
Cheval
Thanks
Philippe
