.CUT Files
ColorSpaced
.CUT Files
Post by ColorSpaced »
I'm not finding any references to opening / converting .CUT files. I need to extract the dimensions from legacy .CUT files.
Any help is appreciated.
Also, is there an online manual for XnViewMP??
Thanks.
m.Th.
Re: .CUT Files
Post by m.Th. »
I assume that you already have .CUT files and you cannot open with XnView, isn't it?
It seems that it is rather easy to open them, according to http://www.fileformat.info/format/drhalo/egff.htm
An oddity is that usually it is accompanied from a PAL file which stores the color palette.
But if you want only the dimensions there are stored in the header of the file:
typedef struct _HaloHeader
  WORD   Width;          /* 00h   Image Width in Pixels */
  WORD   Height;         /* 02h   Image Height in Scan Lines */
  WORD   Reserved;       /* 04h   Reserved Field (set to 0) */
} HALOHEAD;
So, if you just want the dimensions in pixels, you just need to read the first 4 bytes (two words) and group 2 by 2. The first 2 is the Width in pixels, the next 2 is the Height.
As per 'online manual' the best resource is/are these forums.
Also, perhaps you may want read these:
http://www.xnview.com/wiki/index.php/Ca ... _XnView_MP
http://www.xnview.com/wiki/index.php/Xn ... e_solution
m. Th.
Moderator & Librarian
Re: .CUT Files
ColorSpaced wrote:I'm not finding any references to opening / converting .CUT files.
Please activate Show all graphic formats in Tools » Settings... » General
