Hi everyone,
I suspect my question must have been asked before, but I did not manage to locate a similar question.
So, I was wondering, is there a way to show automatically the folder i am browsing on the tree pane? Currently, when I open a folder from the context menu (Browse with XnView) I see the images in the browser but the tree pane does not show the current folder.
Thanks in advance for your answers.
[SOLVED] Show current browsing folder on tree pane
aletron
aletron
Re: Show current browsing folder on tree pane
I retract the question. The folders I was browsing where hidden, that is why I could not see them expanded in the tree pane. Once I allows XnView to show hidden folders, it works fine.
