Can't move Category to top level
schultzter
Post by schultzter »
Good afternoon...
I accidentally move a top-level category by dragging and dropping it into another category. I can't seem to find any way to move it back to the top level!
I originally had this
- Activity
-- activity-1
-- activity-2
- Category
-- category-1
-- category-2
--- category-2.1
--- category-2.2
- Location
-- location-1
-- location-2
And now after the accident I have
- Activity
-- activity-1
-- activity-2
-- Location
--- location-1
--- location-2
- Category
-- category-1
-- category-2
--- category-2.1
--- category-2.2
So how can I get Location back to the top level?! I can't drag & drop it anywhere!!!
Thanks,
Version 0.72 x64 (Dec 19 2014) on Arch Linux
Headed for the second star to the right and straight on 'til morning...
schultzter
Re: [SOLVED] Can't move Category to top level
After fiddling a bit figured-out I could right-click the Category Location and choose Move from the menu. Using the dialog box that comes up I could move it to the top-level again.
m.Th.
Re: Can't move Category to top level
Post by m.Th. »
Yep. Another way: Right-click on the category, select 'Edit' and in the Parent field select the Root (called 'Categories')
m. Th.
