New folder disabled in toolbar
thire
Post by thire »
the "new folder" button is always grey (ie I cannot click it).
I use win XP and win 2000.
Thomas
(Here I just repost this : http://newsgroup.xnview.com/viewtopic.php?p=14445)
Dreamer
Post by Dreamer »
Strange, try to rename/remove xnview.ini file. Backup your .ini file first.
Do you have admin. rights in Windows?
Re: "New folder" disabled in toolbar
thire wrote:the "new folder" button is always grey (ie I cannot click it).
Thomas
This "problem" has to do with showing/hiding folders in Tools > Options > Browser > File List > Items shown in thumbnail mode > Folders.
Most probably, you have disabled "Folders". If you create a new folder, the new folder won't be displayed in the file list, this is the reason why the toolbar button is greyed out if "Folders" is disabled.
Actually, the shortcut "F7" for creating folders is not disabled, this is even a bit of a problem/bug, since you will see the new folders in the folder tree, only.
thire
Post by thire »
Right, that's it and I can see clearly now the problem. Thanks for the answer. And idea how you will resolve it?
Thomas
thire wrote:Right, that's it and I can see clearly now the problem. Thanks for the answer. And idea how you will resolve it?
Thomas
Show folder in FileList
