Filter dialog boxes too small
Brother Gabriel-Marie
Post by Brother Gabriel-Marie »
In MP's filters,
There are:
Enhance detail
Enhance Focus
Focus Restoration
But they don't have any way to modify the intensity - and I wish they did!
This is Enhance Edges. What does the little ticker button do? It looks like the handle for a slider control, but it doesn't slide. If I fiddle with it a bunch, it will finally reset the value (but that is what the other little button is for - reset):
Intensity
Intensity
Re: Focus Filters
Brother Gabriel-Marie wrote:This is Enhance Edges. What does the little ticker button do? It looks like the handle for a slider control, but it doesn't slide. If I fiddle with it a bunch, it will finally reset the value (but that is what the other little button is for - reset):
Please drag one of the corners of the dialog to increase the size of the window.
Re: Focus Filters
XnTriq,
Well at first I didn't understand why you would say that, because the window is PLENTY large enough to accomodate a slider bar:
room enough for a slider bar
I mean, I saw all that space in the top and the bottom of the Parameters area, and my brain said, "enough space! - and in the default window size for the dialogue"
Then I got to thinking about that.
And I realized that the slider bar actually does appear if you stretch the window horizontally.
stretched dialogue
stretched dialogue
In conclusion to all that, I reckon that I should have guessed that.
I wonder if the default dialogue shouldn't be wider in order to suggest that that really is a slider bar (I did recognize the handle as belonging to a slider control - but I am a programmer...)
or, perhaps the slider bar could go beneath the textbox with the up-down control to take advantage of all the vertical space without requiring a larger dialogue.
I dunno - just some thoughts here on intuitiveness.
Hi, Br. Gabriel-Marie (-:
Yes, I absolutely agree and decided to move this topic to bug reports.
m.Th.
Re: Filter dialog boxes too small
Post by m.Th. »
+1
+1
Two issues here. Both needs implementation.
m. Th.
Problem no longer occurs in 0.84 and later: Default size of filter box has been adjusted.
Textbox is still right to the slider but I think that doesn't matter.
:arrow: Closed
