Opening PDF files with Unicode characters in filename
The following file can only be opened if the è in the filename is changed to e :
Modèle de test.pdf
(23.93 KiB) Downloaded 116 times
The file opens normally in other software (Adobe Reader, NitroPro 8 and IrfanView...)
The file can be opened in XnViewMP (0.69 64-bit gs9.10 64-bit) if it is renamed 'Modele de test' ...
Possibly a known Ghostscript issue when using Unicode characters with Windows, possibly resolved with alternative coding??
http://stackoverflow.com/questions/2125 ... parameters]
m.Th.
Re: Opening PDF files with Unicode characters in filename
Post by m.Th. »
From the SO.com question which you linked I think that's pretty clear what needs fixing...
m. Th.
See Issue 499 for current status and details.
The test PDF file included in the first post of this thread still doesn't open in XnViewMP 0.75 (beta)... :(
cday wrote:The test PDF file included in the first post of this thread still doesn't open in XnViewMP 0.75 (beta)... :(
Strange, i can open it now
@cday: Could you please try and see whether the problem still exists in current XnView MP 0.84?
helmut wrote:@cday: Could you please try and see whether the problem still exists in current XnView MP 0.84?
Opens correctly now, I don't know what happened last time. :D
Time heals. ;)
